FOUNDATION Fieldbus
How to configure FBUS in my applicatioin?
I have NI FBUS interface. I want to configure the FBUS device, such as, set address, in my application. But thers is no SDK for "NI FBUS Configurator". What can I do?
(9,173 Views)
NI does have an advanced API library so called "Configurator API Library", which covers most of the configuration functions including Set Address and Set Tag; but that's not free. You can contact fieldbus.support@ni.com if you are interested in this library.
However, if you are developing your application using NI LabVIEW, then the NI-FBUS FFLV VI library already includes VIs supporting Set Address and Set Tag; you can set address/pdTag within your LabVIEW program easily.
(9,168 Views)
Can I use OPC to change the Address and Tag?
(9,124 Views)
The NI-FBUS OPC Server does not support any configuration functions like "Set Address", it only supports data access (Read/Write).
Actually NI has a special library so called "Configurator API library", which supports Set Address, Set pdTag and other configuration functions used by NI-FBUS Configurator. However, this library is not free, please contact fieldbus.support@ni.com for more information.
In addition, you can use LabVIEW VI library FF-LV, which has VIs support "Set Address" and "Set Tag".
(9,118 Views)
Is this "Configurator API library" discontinued ?  I would like to change tag and address programmatically from a vb.net program and I interested buy this configuration library.
There are some messages in this forum saying that it is possible to change device tag from Labview. Can I create dll, if I buy Labview Professional,  to change device tag and call this dll from my vb.net program ?  May I deploy this dll and Labview runtime with my application?
(7,140 Views)
Yes, "Configurator API Library" is discounted.
Creating LabVIEW dll is a feasible option. You can deploy it with LabVIEW runtime.
Please contact fieldbus.support@ni.com for more detail technical support.
Feilian (Vince) Shen
(7,109 Views)
