FOUNDATION Fieldbus
Fieldbus AT-FBUS card compatiblity
I am currently using a older AT-FBUS card in a product test station installed in an ISA slot.  The station computer's operating system is XP and is using NI-FBUS Communications Manager Ver. 2.3.6.
Is it possible to use this card with the lastest version of the Communications manager?  Is it possible to use lastest CD of NI-FBUS Communications Manager to install the  latest drivers?
Thanks for your help,
Bryan
(7,623 Views)
Hi Bryan,  yes, you can use the AT-FBUS card with the lastest version of NI-FBUS Communications Manager (version 3.1.1); and the latest CD of this software is version 3.1, which has slight difference with 3.1.1 version.
However, if you are using some application programs based on NI-FBUS CM 2.3.6 version in your test station, probably you can not run the application programs directly with the latest 3.1 or 3.1.1 version NI-FBUS CM. The reason is that NI-FBUS CM changed its API interface since 3.0 version, you would have to upgrade your application programs by simply rebuilding the application with the NI-FBUS 3.1 or 3.1.1 version library.
(7,619 Views)
Is it AT-FBUS (ISA) board suported on nifb 3.x versions anymore?
(6,138 Views)
Zry, wrong version on my last post.. Is it supported on 4.x version drivers?
(6,137 Views)
NI-FBUS 4.x does not support AT-FBUS anymore.
Feilian (Vince) Shen
(6,130 Views)
