FIRST Tech Challenge Discussions
Reset motor encoder block resets to zero through every iteration
I have a program with an infinite loop that prints the current motor position to the screen. However, when I run it, it resets to zero through every iteration.
Does anyone know why this is so?
(6,137 Views)
One of the problems I see is you have no constant set for the power associated with your motor, so it shouldn't move.  This may give you a value of zero and appear that it is resetting.
(5,312 Views)
