Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
FIRST Robotics Competition Discussions
feedback node doesn't reset on "stop"
I've been having problems with my feedback nodes not resetting when I stop the simulation. When I wire a value to the initializer terminal, the node simply sends the value wired to the initializer terminal, instead of storing the input value for one loop. I have seemed to get around this with putting a "while" loop around the whole VI instead of testing with a "continuous run", however if I leave subVIs like this, they hang up the VI where they are used.
What can I do to get around all this?
~Marshal
Marshal Horn
(9,027 Views)
Marshal,
I don't know if I completely understand what you are trying to accomplish. Could you post a screenshot of your block diagram for reference?
If you are trying to access data from a pervious iteration of a loop in the current iteration might I suggest using shift registers. A tutorial on shift registers can be found here.
I have also included a screen shot of a block diagram demonstrating an initialized and an uninitialized shift register. Please let me know if you have any questions.
Mark
NI App Software R&D
(4,136 Views)
In addition to posting a screenshot, NJKirchner(one of our venerable LV Champions) has recommended a great tool that will help in elaborating the issue you are experiencing with your code. Here's his post.
The better we understand your issue, the better we can help!
-Emilie
(4,136 Views)
S'okay, I was simply expecting the feedback node to reset when I pressed "abort execution". I didn't realize Labview didn't differentiate between another call and another run.
The reason I'm not using shift registers is because I'm working on subVIs which themselves are not in a loop. I'll just wire up all the resets and reset everything before I test it.
Thank you, Emilie! There was also a thread on Chief Delphi that was asking about posting VIs more easily.
Marshal Horn
(4,136 Views)
