‎03-11-2010 07:18 PM
I iimagine this is very simple for someone, i am using the default arcade for our robot. When i move the joystick forward the robot moves forward as it should, and then when i move the joysticke backward the bot moves in reverse as it should, but if i move the stick to the right the bot moves left and vice versa, i am sure there is a simple change i can make but i am not sure where.
any help is greatly appreciated
thanks john
‎03-11-2010 08:14 PM
Hi John - I think you just have the channels for the left and right motor reversed. You can either swap the PWM cables at the digital sidecar, or in Begin you can change the order of the channels you're using (swap the PWM channel for the left motor with the one for the right motor and vice versa).
‎03-12-2010 07:54 AM
ok i will try that, i did go into the begin vi and there are two t-f switches and with those i can control the x axis , but
the left and right motion is a y axis issue, so i will try what you offered,
thanks a bunch John
‎03-12-2010 12:16 PM
thanks it worked well, i am all squared around:)
john
