02-28-2012 04:18 PM
Hi -
We are having a problem where the cRIO "crashes" or keeps losing comms from the laptop when we try to run the code for vision processing on the cRIO. We used the NI Vision Assistant to generate code which we put into Labview to run on the cRIO, and the actual NI Vision program works when the VI is ran locally on the computer. It seems that the cRIO will crash when we start particle filtering. Is there something that we might have missed?
Here is the vision processing VI:http://dl.dropbox.com/u/58862361/Vis...eFilterting.vi
And here is how it is used: http://dl.dropbox.com/u/58862361/Vision%20Processing.vi
We are using a 4-slot cRIO.
Jason Law
02-29-2012 01:00 PM
Hey Jason,
It sounds like you may be starving the processor (maxing out the CPU or getting stuck in a loop). If you look at the charts tab while you are running the code what is your processor/memory usage?
