FIRST Robotics Competition Discussions
MXP current capability
The MXP spec says that the 3.3 and 5V can be used to operate custom electronics.  What are the current limits?
(5,008 Views)
Just to be clear.  I assume that you are pointing to the Power Output table in the spec.  The roboRIO User Manual talks about a 5.0V rail and block diaghram shows the onboard DIO, MPX, SPI, and AI using 5.0V.  Is the 1 A of 5.0V from the table the total that is available for all 5.0 V functions?
(4,175 Views)
Yes. The user 5 V rail is all shared across all places you see reference to 5 V (such as AI, DIO, SPI, etc.). Other integrated places where 5 V happen to be used are not included such as USB vbus. You can read the current and voltage of the user rail in the power API of WPILib.
(4,175 Views)
