Labview dying
Jon236
Member
Labview dying
My installed version of Labview suddenly decided not to work last Friday.  I get a dialog box stating 'License unavailable' and it invites me to register my installation.  I have done so, both on-line and using the 20-diogit key, to no avail.  I have reinstalled the current version numerous times, to no avail.  I was promosed an answer by today from NI.  They have referred me to you.
Tags (2)
17 REPLIES 17
Justin_P
NI Employee (retired)
Re: Labview dying
Message contains a hyperlink
Hi Jon,
Are you using the FIRST Robotics version of LabVIEW?  Are you following the steps in this article? Could you give me a screenshot of the actual dialog you are getting?
Justin Parker
Product Support Engineer
Jon236
Member
Re: Labview dying
I finally deleted Labview and re-installed it from the DVD.  When I then started LabView, I got a choice of a 30-day trial, even though I had used License Manager to successfully register.  LM indicates I will expire 1/15/10.  So in 30 days, we shall see!
Justin_P
Re: Labview dying
So what version of LabVIEW do you have?
Justin Parker
Jon236
Member
Re: Labview dying
8.5.1
Highlighted
sciencewhiz
Active Participant
Re: Labview dying
Can you post a screenshot of the license manager (similar to the one in the article that Justin posted).
Jon236
Member
Re: Labview dying
Message contains an attachment
Here it is!
Justin_P
Re: Labview dying
When does your FRC license say it will expire?
Justin Parker
Jon236
Member
Re: Labview dying
In License Manager, Jan 15, 2010
When I start LV, I'm in a 30-day countdown evaluation period
Justin_P
Re: Labview dying
I'm pretty sure that your LabVIEW Professional Development System is on the 30 day trial.  I think that your LabVIEW FRC should keep working until 2010.  Do you have a license for regular LabVIEW?  Or did you just download the trail version?
Justin Parker
