01-19-2017 07:20 AM
Right out of the box with 2017 LABView software, I cannot get the USB camera to work. We have used a USB camera for the last 2 years with no problems. We are developing with LABView. The example LABView vision code does not work either.
The dashboard does not show any "USB" options in the camera dropdown.
Has anyone else had problems with getting USB camera to work with LABView?
01-19-2017 04:07 PM
PS. We have installed the Labview update...
01-20-2017 06:58 AM
My team is having problems with Labview USB camera's as well. I have uninstalled all versions of Labview and reinstalled with new version and ran updates. Our vision setup is Microsoft Life webcam connected directly to laptop and just running vision example. We get a mask however, we're not getting a high enough score to get distance and a green box. We tried using a different webcam (Logitech) and it too was in the 30s score wise. Used the webcam on laptop and got a better score in the 50s but still no distance readings or green box. I've lowered the settings for score with no effect. We've changed camera settings on example code with no effect either. The example pictures from file work just fine, we do get distance and a green box which is telling me our camera is the issue. We are now thinking of using a IP camera.
01-23-2017 03:12 PM
Efiegl, Did you get your camera working?
Do you have your camera connected to the roboRIO? If so, you have to "Enable Vision" in the robot main. To get this to say enabled, make sure you have Enable Vision control set with the green light lit, then right click it and go to Data Operations > Make Current Value Default. This will make sure that vision is always enabled.
Let me know if that helps.
Ryan
01-23-2017 03:19 PM
Hi swheeler90,
What does the target look like that you are using? I created a scaled down version of the boiler (only 2.9 in diamater) to use for testing. Make sure you have a light or can "see" the target enough to filter it out from the background. Then from there you should be able to use it just like the real thing.
I will be doing a demo and will talk about my target and some troubleshooting tips tonight if you want to join in. I will be live from 5-7pm central time https://techjoynt.zoom.us/j/
Let me know if you get yours working.
Ryan
01-26-2017 08:44 PM
Actually, we are not even using targeting, so we don't have vision enabled. We are only trying to see the video stream from the camera on the Dashboard.
01-26-2017 09:10 PM
01-28-2017 09:18 PM
Ok, so I am experimenting with a dual usb vision option right now and remembered your question.
Check your Vision processing loop to make sure your USB camera is addressd correctly.
With the "Enable Vision" button off or disabled in the Robot Main.vi I was able to stream 2 USB Cameras to the dashboard.
Here is a screen shot of my Vision Processing.vi and the Robot Main.vi so you can see what I had set.
For a single camera you can use either USB port and still use "USB 0". From what I can tell the First camera pluged in will get USB 0 and the second camera will get USB 1. And they should stay that way unless you unplug either of them when the power is on.
I hope this helps.
Ryan
02-04-2017 06:10 PM
Hi Ryan,
Can you give a little more detail about how to display 2 USB camera images in Dashboard ? I repeated the VI shown in your attached files. In Dashboard, I can only see show either the camera 0's image or camera 1's image at Camera tab, not both camera 0 and camera 1 at the same time.
Did you change anything in Dashboard? Any other changes in vision processing.vi like port number or camera 1's IP address etc ?
Thanks!
Jun
Team Tech Tiger
02-05-2017 04:38 PM
I was having issues getting the Dashboard to display the camera feed intermittantly using a USB camera. I found the below worked for enumerating the camera and getting video:
1. Run roboRIO code
2. Open Driver Station and Dashboard
3. If 'No Camera Selected' was the only option or selecting 'Camera' did not work, reboot the roboRIO with Reset button only (but not the robot's WiFi Router)
4. Allow roboRIO to reconnect, camera would reinitialize and we could get video
@efiegl , you may want to add an Image Display Control to the Vision Processing VIs front panel and run the code from the LabVIEW project. This will allow you to see if you are getting any images at all!
Display an Image
http://zone.ni.com/reference/en-XX/help/370281P-01/nivisionlvbasics/display_an_image/
