FIRST Robotics Competition Documents
annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
[FRC 2016] Robot Simulation Tutorial
Kevin Fort
Principal Software Engineer
NI
Commentaires
sciencewhiz
activé
In the simulated robot, where is the ultrasonic sensor mounted?
RyanNaz
activé
There is some crucial information missing from this document, and the missing information is placed in an HTML file in your project folder.  It's titled "Robot Simulation Readme.html"
Please add in all the information below into the PDF.  It skips on all of the servos for the arm and camera are not even mentioned in the PDF.
Actuators on this simulated robot
  1. Left Motor
    • Digital Module = Digital Module 1
    • PWM Channel = PWM 1
  2. Right Motor
    • PWM Channel = PWM 2
  3. Camera Servo
    • PWM Channel = PWM 5
    • Angular Range = 170
  4. Arm Servo
    • PWM Channel = PWM 6
  5. Gripper Servo
    • PWM Channel = PWM 7
Sensors on this simulated robot
  1. Encoder on Right Motor
    • A Channel = DIO 3
    • B Channel = DIO 4
  2. Encoder on Left Motor
    • A Channel = DIO 5
    • B Channel = DIO 6
  3. Gyro
    • Analog Module = Analog Module 1
    • Analog Channel = AI 1
  4. Ultrasonic
    • Ping Digital Module = Digital Module 1
    • Ping DIO Channel = DIO 1
    • Echo Digital Module = Digital Module 1
    • Echo DIO Channel = DIO 2
  5. AXIS M1011 Camera
Thanks to Rachel Holladay from Team Combustion #1912 for this information!
masonwong
activé
Is there any way to set the initial position of the robot when the simulator loads?
netsirk
NI Employee (retired)
activé
Unfortunately, there is no way to set the initial position of the robot.
Kristen M
Automated Test Product Marketing Engineer
netsirk
activé
Also, please note the actuator and sensor data has changed for the 2015 season. The information communicated above is outdated.
Kristen M
PeterGlass
activé
Can anyone help with this error:
Error -310194 occurred at NI_Robotics_Simulator.lvlib:ODESimulator_Motor.lvclass:Get Motor Index By ID.vi->NI_Robotics_Simulator.lvlib:Get Actuator By ID.vi->DC Motor Controller Simulator.lvclass:Initialize (Simulator).vi->WPI_MotorControlOpen&ConfigurePWM.vi->WPI_MotorControlOpen Talon.vi->Begin.vi->Robot Main.vi
contributeurs
