FIRST Robotics Competition Discussions
Error compiling code
Last week I made a code in command and control, I compiled it in both RoboRio and Robot Main but I got the following error where I lost the connection, I already tried with two different computers, with different codes, formatting the RoboRio, changing Roborio but I can not fix it, I ask for your help
(3,096 Views)
Hey Manuel226,
I don't have a specific root cause figured out yet but here are two sources of the same error that I'm investigating and I thought sharing might be helpful. In general, here are some general steps we can take to narrow things down as well.
Is this happening with just this projects or all projects?
-Try making a new project from scratch and see if it persists
Does this persists with sw configuration, or hardware?
-Try running a fresh image to the roboRIO and try this code and an untouched template
-If you have multiple roboRIO we can check if the issue follows the hardware in any way
What are the possible causes of error 0x661? - https://forums.ni.com/t5/NI-Linux-Real-Time-Discussions/What-are-the-possible-causes-of-error-0x661/...
Exclamation Failed to Deploy Target Settings Error URGENT - https://www.chiefdelphi.com/forums/showthread.php?t=138447
 Best,
JY
Application Engineer, RF and Communications
(3,047 Views)
