FIRST Robotics Competition Discussions
2014 season robot
is there any way to controll our 2014 robot with the new software?
(6,546 Views)
There was a bit of discussion about this in the following thread: https://decibel.ni.com/content/thread/26700?tstart=30  It appears they had some success with the cRIOs.
(5,293 Views)
We talked about getting a 4-slot cRio controller working in this discussion
Doug Norman did some testing and was able to get a starter LabVIEW project working.
We were also able to program our last years robot using the 4-slot cRIO with the following abilities
  • 2 wheel tank drive
  • 1 Motor to arm the thrower
  • 1 solinoid to fire the thrower
  • 1 motor to retrieve the ball
  • 1 Game controller
  • 2 limit switches
Note that 8 slot chassis are not suported by the 2015 software.
Mark
(5,293 Views)
My question is the students use Java will the new driver station support
the Crio running java?
Rob
(5,293 Views)
Yes, the most recent DS release does support that.
(5,293 Views)
You will need to select the '14 robot protocol on the settings tab for it to connect, though.
(5,293 Views)
