DIO Streaming Example for the NI PXIe-5644R »
This example provides a DIO interface using the front-panel VHDCI connector on the VST, capable of rates up to 125 MHz, or 125 MB/s, bi-directional. It is useful for high-bandwidth, low-latency data exchange with other devices. |
Description: This example provides a simple source synchronous data transfer interface that is capable of streaming data to another DIO device at up to 125 MHz. The output physical interface requires eight DIO lines (one byte) for data transfer, one line for data valid signaling, one line for flow control, and Clock Out for forwarding the data clock; therefore, a total of ten DIO lines and the Clock Out line are required for this IP, enabling generation up to 125 MB/s. The input physical interface and bandwidth is identical with the exception that Clock In is used rather than Clock Out.
Additional Documentation:
Compatibility:
Dependencies:
FPGA Footprint:
Xilinx Virtex-6 LX195T
Latest Version:
Previous Versions:
Note: All source on this community is distributed using VI Package Manager (VIPM). For more details on VIPM, please read A Note on VI Package Manager
