DSP
Channel Emulation IP »
This IP implements inline, real-time DSP in LabVIEW FPGA to apply arbitrary channel models to RF data. Fading profiles are computed in real-time on the host, and dowloaded to the FPGA where they are interpolated and applied to the data stream.
Control
Power Servoing IP »
This IP uses an FPGA-based control loop to rapidly adjust device output power to reach a desired input power, when an load or amplifier of unknown gain is connected between the output and input.
Digital Protocols
I2C IP »
This IP implements inter-integrated circuit (I2C) communication, including support for both master and slave functionality.
SPI IP »
This IP implements serial peripheral interface (SPI) communication, including support for both master and slave functionality.
RFFE IP »
This IP implements MIPI RF front end (RFFE) communication, including support for both master and slave functionality.
Ryan Verret
Product Marketing Engineer
Signal Generators
