Example Code
Synch AI-AO to an External Sample Clock Generate by Onboard Counter Using LabVIEW with DAQmx
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
This Example Program synchronizes an analog output and an analog input task to a external sample clock generated by a counter on the same board.
Description
This Example Program synchronizes an analog output and an analog input task to a external sample clock generated by a counter on the same board. This is done using a counter output frequency task.  The AI and AO tasks reference the output terminal of the counter output task and therefore sample/update at the rate that the counter task is going.
Requirements
  • LabVIEW 2012 (or compatible)
  • DAQmx 9.5.5 (or compatible)
  1. Configure the Controls on the front panel to fit your application
    1. Select the counter output and the sample clock frequency
    2. Select the physical channels for the AI and AO tasks.
    3. Select the Waveform parameters for the AO Task.
  2. Select run.
This Program could easily be scaled for multiple AI and Multiple AO channels if needed. a simple modification of the physical channels and the polymorphic DAQmx Write or Read VI would be in order.
VI SnippetMulti-Function-Synch AI-AO to Internal Counter LV 2009 Express VI Snippet.png**This document has been updated to meet the current required format for the NI Code Exchange.**
Charley Dahan
Global Account Manager
Comments
dtraxler
Member
Member
on
Does not appear to be anything in the zip file.
