Overview
This Example Program synchronizes an analog output and an analog input task to a external sample clock generated by a counter on the same board.
Description
This Example Program synchronizes an analog output and an analog input task to a external sample clock generated by a counter on the same board. This is done using a counter output frequency task. The AI and AO tasks reference the output terminal of the counter output task and therefore sample/update at the rate that the counter task is going.
Requirements
This Program could easily be scaled for multiple AI and Multiple AO channels if needed. a simple modification of the physical channels and the polymorphic DAQmx Write or Read VI would be in order.
VI Snippet
Does not appear to be anything in the zip file.
