Example Code
open StateChart
Code and Documents
Overview
open StateChart für LabVIEW 2012 and higher
Description
open StateChart is a small collection of vi's for modelling State Charts
- direct on the Block Diagram without any translation.
- parallel nets are possible
- local and global states
- eventdriven and signaling state change
- LGPL license
- examples for fast access
- easy configuration with express vi's
- notification of active states on the Block Diagram
just install the vip package
Requirements
Software
LabVIEW Development System 2012 or higher
Hardware
Additional Images or Video
Comments
CharlesB64
on
Looks interesting, but an introduction document, or a tutorial, would be great to have an overview of the possibilities
Lutzi
on
we have an little tutorial on the tool,
but it is in german,
but we hope it will help understanding the use of the Toolset.
kashiruvana
on
Curious if this add-on is only compatible with German versions of LabVIEW?  I'm using 2013 SP1 and VIPM is telling me that open StateChart is not compatible.
______________________________________________________________________
The avatar is for the best weapon in any game ever. But nobody goes there anymore.
CLAD, LV2013, LV2015
Lutzi
on
hello kashiruvana,
the tool is also in english.
we have tested it with your version.
you can find it on the LabVIEW Tools Network by searching "open"
Lutzi
on
hello kashiruvana,     the tool is also in english.  we have tested it with your version.  you can find it on the LabVIEW Tools Network by searching "open"
Lutzi
on
hello kashiruvana,
i have tested it with your version.
Am 09.11.2015, 20:33 Uhr, schrieb kashiruvana <web.community@ni.com>:
kashiruvana
commented on the document
"open StateChart"
To view all comments on this document, visit:
https://decibel.ni.com/content/docs/DOC-36329#comment-45880
kashiruvana
on
Thank you for your quick response!  I've actually just solved the problem--VIPM was telling me that open StateChart was not compatible with my version of LabVIEW, but it was actually because I didn't realize I was using an older version of VIPM.  I upgraded that and was able to install open StateChart with no problems.  I'm looking forward to using it!
Contributors
