Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
I created a small example how to merge multiple CAN DBs (.dbc, .ncd or .xml) into 1 XNET DB (FIBEX xml) containing only 1 CAN cluster. This is needed if you want to use multiple CAN clusters on the same physical interface using NI-XNET 1.0. Example is for LabVIEW 2009.
Right now the code onyl works if there are no duplicate frame/signal names. Mode dependend messages are not supported either. Feel free to customize it for your needs.
Andreas
Would you be able to convert from LabVIEW 2009 to LabVIEW 8.5.1? Appreciate your help.
Can you add multiplexed signal(s) support.
Hi all,
I'm trying to use this code but when I open the "XNET merge dbc files.vi" from the LLB, during load LabView (I'm using LV 2013) ask me to select the "XNET String To IO Name (Database Filepath).vi" (...and if I skip this step, many other similar requests appear).
I've installed X-NET 1.8... why LabView cannot find trhe requested VIs? Where I can find these VIs? I need to install some other module?
Please could you help me?
Thank you in advance
P.S.:
Exactly the same happens using files contained into the XNET merge dbc files 85 with LB 8.5.
