Example Code
Writing Data to a File Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example shows two possible methods for writing data to a file to save/log/view later. These two methods include the "Write to Measurement File" Express VI and the "Write to Spreadsheet File.vi" function block.
Description
This VI creates a user defined amount of random data in the form of random numbers. It then takes the data gathered and writes this data to a file. The format of the file can be specified in the Express VI. The format of the function block can be opened in different programs (such as notepad, Excel, word, etc.)
Requirements
  • LabVIEW 2013 (or compatible)
  1. Set File location and name of file on the VI's front panel by clicking on the folder icon.
  2. Run VI
  3. Open desired file
VI Block Diagram
Rob W.
Comments
okmanto
on
Hi guys,
is there any one who is able to help me? my problem is actually very simple but i cannot figure out it.
My labview always writes data in every 1 ms, but i need the labview to write the data at every 30 minutes, could you show me how to make a program for this?
my samples are continues samples, 1k samples, 1k hzs
many thanks
