Example Code
Write and Read Text File As Appended Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI shows how to write and read text file as appended using LabVIEW
Description
The program consists of a state machine, where it first writes the number of samples that the user indicates, random numbers are generated between 0 and 10, which are stored, then goes to the next state where the information is obtained from the file , The samples are plotted and the number of elements in the file is obtained as well as the average value.
Requirements
Software:
  • LabVIEW 2012 (or compatible)
1. Select how many element do you want to write.
2. Run VI.
3. Notice that every time application run, elements inside report is increasing by "Numbers to Write."
Additional Information or Resources
Arturo Gómez | Applications Engineering
Certified LabVIEW Associated Developer
National Instruments Latin America
01-800-010-0793
ni.com/support
Comments
HunterSeeker
Member Member
on
Por favor incluya una captura de pantalla en todos ejemplos.
Gracias!
Todd S.
NI Employee (retired)
on
Gracias por subir este codigo a la Comunidad! Cuando tengas tiempo, por favor haga las siguientes cambios:
1.  Anadir una foto del block diagram para darnos idea como funciona su codigo
2.  Cambiar el nombre del archivoadjunto a incluir la version de LabVIEW ("_lvXX.vi")
3.  Cambiar el titulo del documento para que no sea una pregunta (queremos que aparezca en una forma)
Otra vez, gracias por incluyendo este codigo en la Comunidad!!!
Todd S.
LabVIEW Community Manager
