This example shows how to write mutiple messages to a CAN bus using different sample rates. For example, you can be sending message 1 at a rate of 10 Hz and message 2 at a rate of 30 Hz. To do this you have to configure things a little bit differently.
The attached VI is written in LV 7.1.1. To use it, you will have to have CAN hardware and you will have to have your messages configured in MAX.
it's a good example for me, but i have no hardware currently, could you send us realated *.vi, thanks!
Thanks for posting, Scott. Could you embed the block diagram image in the description area so we can see what the code looks like? Also, please rename your attachment to include the LabVIEW version. "_LVxx.vi" is good enough.
Good VI, Thanks.
Great VI. However I have listed several channel names and I can only get the VI to push the first index channel to the CAN network.
