Example Code
Write Data to User-Selected Cell in Excel Spreadsheet
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example demonstrates opening Microsoft Excel and writing data to the active cell (the cell that is selected).
Description
ActiveX is used to communicate with Microsoft Excel. The active cell will start off as the upper left hand corner of the spreadsheet. The front panel of this example has three buttons, Open/Create to create a new Excel spreadsheet or open an existing one, Write to Active Cell to write random data, Stop to stop the program. Property nodes are used to open or create the Excel sheet and write to the active cell.
Requirements
LabVIEW 2012(or compatible)
1. Make sure Excel is closed
2. Open and Run the VI "Write to Excel Active Cell_LV2012_NI Verified"
3. Choose if you want to Create a New File or an Existing one
4. Click on Open/Create
5. Choose the file from the dialog if you chose open existing. (Skip this Step if you clicked on Create New File)
6. Choose the cell where you want to insert the data is the excel sheet
7. Select the number of rows and columns to be inserted
8. Click on Write to Active Cell and check updated excel sheet
9. Stop the VI
undefined
 undefined
Product Support Engineer
Comments
jjjmirko
on
could you convert the file for previous labview version?
freighTrain
NI Employee (retired)
on
Which version?
Humphrey H.
Applications Engineer
pmv
on
Can you please convert it into labview version 2010
lucian.grec
on
how do you select the active cell programatically?
