Overview
This VI uses the System Exec.VI to run a command line in DOS that will shut down Windows based on the string input into the command line.
Description
This code consists on using the System Executive VI to run a command line in the command prompt. In the block diagram is a list with the possible commands to run. It is important to notice that running a shutdown command will shut the computer you are in, so it is recommended not to use the shutdown command.
Requirements
LabVIEW 2012 (or compatible)
1. Verify you will run the desired command.
2. Run the VI.
Good call including the "warning" image. People need to understand that.
As far as I know, this easiest way will work from Administrator account only.
