These VI's wrap calls to the .NET Framework and allow the caller to create new entries in the Windows Event Log, which can then be viewed from the Event Viewer, generate SNMP traps, etc.
Full description is given on my blog.
Other requirements:
.NET Framework and a Windows Operating System
As far as I know I need to create or modify a message file so that eventIDs are known. I believe if I use a WriteEvent using an eventInstance, I can create a new eventID message. Except I do not know how to declare values. Any thoughts?
