This VI allows the user to use a multiple selection listbox to perform several tasks. For example, if there are several tests that can be run, this VI will let the user choose multiple tests that will be run in sequence.
Description-Separate-2Example code from the Example Code Exchange in the NI Community is licensed with the MIT license.
Can't open this vi on LV2015 ... error is vi is too old to convert (LabVIEW 4?)
I just updated the VI to be saved in LabVIEW 8.0, which can be opened in any newer version. I also did some re-architecting to use an Event Structure (did have a polling greedy loop), and auto-indexing tunnels.
