Example Code
Using NI-SCOPE and Exporting Triggers
Products and Environment
    Hardware
  • Modular Instrumentation
    Software
  • LabVIEW
    Driver
  • Other
Code and Documents
Overview
This example uses the NI-SCOPE driver to perform a single configured acquisition off of a single channel.
Description
The acquisition will start on an analog edge and this start will cause a 5 V TTL trigger to be exported on a desired PFI/PXI Trigger/RTSI Line. The NI-SCOPE Export Trigger VI can be found under Measurement I/O»NI-SCOPE»Triggering»niScope Export Trigger.vi.
Requirements
  1. LabVIEW 2012 (or compatible)
  2. NI-SCOPE
  1. Compete device configuration, like Resource Name , Channel Name(s) and Trigger settings..
  2. Run the application
 VI Snippet
Dan King
Comments
gurusj
on
Thanks a Lot for the Post...
