Example Code
Using DLLs Built With Visual C++ In LabWindows/CVI
Products and Environment
    Software
  • LabWindows/CVI
Code and Documents
Description
Overview
The example will guide you through using DLLs built using Visual C++ in the C compiler of LabWindows/CVI
Description
While calling C based DLLs in LabWindows/CVI is a breeze, calling DLLs built in other languages such as Visual C++ can be somewhat more involved. This example will demonstrate how to properly set up a project in Microsoft Visual Studio to build a visual C++ DLL. Then, we will call functions from that DLL in LabWindows/CVI.
Requirements
  • Microsoft Visual Studio 2010 (or compatible)
  • LabWindows/CVI 2013 (or compatible)
  1. Open The DynamicLibrary.sln solution from the Visual Studio VCPP project folder
  2. Analyze solution and project. Note the MathFuncsDll.h file
  3. Notice that the function declarations in the .h file also include the following:
      extern "C" __declspec(dllexport) double __cdecl DGAdd(double a, double b);
      extern "C" __declspec(dllexport) double __cdecl Subtract(double a, double b);
      extern "C" __declspec(dllexport) double __cdecl Multiply(double a, double b);
    The "extern "C" __declspec(dllexport)" and "__cdecl" declarations are necessary to be able to use this DLL in code that will be compiled with a C based compiler.
  4. If no changes are made skip to step 5. If you do make changes, mode the modified .h, .lib, .pdb, and .dll files over to the CVI project folder of interest.
  5. Open the "dll test.cws" workspace from the CVI project folder.
  6. Open the Command-line Application.c file and analyze
  7. Notice that the only files included in the project are the .h and .lib files. Note: DO NOT INCLUDE .DLL FILE
  8. Run program and notice use of functions from Visual C++ dll.
Calling a Visual Basic DLL From LabWindows/CVI
Daniel G.
Semiconductor & Wireless
Comments
Bill2@NGC
on
Creating the DLL is not discussed.  Is it assumed that the C++ DLL has already been built and we then have to add the extern "C"?  Or do add that before we create the DLL?  Thanks.
AleAlejandro
NI Employee (retired)
on
Hi!
You would do that before you create the DLL as noted in step 2 and three. You have to add the modifiers to the .h file and then build the project.
In the calling program, include the .h and .lib file and we will be able to call the functions. The attached .zip file contains the example code on how to accomplish this on both the creating the .dll side and calling it. I hope this helps!
Ale
Daniel G.
Bill2@NGC
on
Hi Ale,
Thanks for the quick response and I understand it now. But nowhere does it say build DLL now. It’s kind of implied in Step 3, but not stated outright. Perhaps it’s obvious to a programmer experienced in this, but I’ve never built a DLL before, so I need it spelled out. Thanks again for your help.
Bill
eranv
on
i am trying to use C function that wrapped C# dll and call it via CVI, without success. can you advice please?
AlexafelderDeni
on
thank you very much indeed for very useful example code
Gareth@
on
I'm getting errors when attempting step 8. Below is the build output:
Command-line Application.c - 6 errors, 4 warnings
 "MathFuncsDll.h"(2,12)   Warning: Empty declaration.
 "MathFuncsDll.h"(2,12)   syntax error; found 'string constant' expecting ';'.
 "MathFuncsDll.h"(2,12)   Unrecognized declaration.
 "MathFuncsDll.h"(3,12)   Warning: Empty declaration.
 "MathFuncsDll.h"(3,12)   syntax error; found 'string constant' expecting ';'.
 "MathFuncsDll.h"(3,12)   Unrecognized declaration.
 "MathFuncsDll.h"(4,12)   Warning: Empty declaration.
 "MathFuncsDll.h"(4,12)   syntax error; found 'string constant' expecting ';'.
 "MathFuncsDll.h"(4,12)   Unrecognized declaration.
 55, 1   Warning: HIPAR tag - Parameter help for name declared but parameter not defined in function.
I haven't modified the CVI project or the C++ code. I am running CVI 9.0
