Overview
This utility VI will turn off Auto Grow on all structures on the block diagrams of all VIs in a given folder, including all subfolders and LLBs.
Description
Some LabVIEW developers can found Auto grow property a bit challenging in their applications while developing the code. Additionally, some developers do not want their block diagrams are changeable by modification and auto grow. So with that example, disabling auto grow process is getting faster and easier for single and multiple VIs.
Requirements
Software:
1. Select VIs' folder to implement utility.
2. Do not forget to get back up of folder contents.
3. Run VI.
Note: This VI uses the subVI that does not reside in palettes. This subVI can reside in "Utility" folder in "Program Files." Also, make sure to make a backup copy of the folder of VIs before running this utility.
Thanks for this exempl, but just one question : Why do that ? Why turn off auto grow ?
As I mentioned in this blog post, I don't like Auto Grow because it often explodes my diagrams. With auto grow disabled, I can manually resize structures when I want to.
-D
Brilliant! I noticed some uncontrollable diagram explosion in a LV2010 VI opened in LV 2015 when browsing through nested structures and this tools fixed the problem in an instant.
Moo.
I've never had a diagram grow just by switching through a Case structure, but it happened today. Darren's utility saved my sanity postponed my breakdown.
