Example Code
Turn Off Auto Grow Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This utility VI will turn off Auto Grow on all structures on the block diagrams of all VIs in a given folder, including all subfolders and LLBs.
Description
Some LabVIEW developers can found Auto grow property a bit challenging in their applications while developing the code. Additionally, some developers do not want their block diagrams are changeable by modification and auto grow. So with that example, disabling auto grow process is getting faster and easier for single and multiple VIs.
Requirements
Software:
  • LabVIEW 2012 (or compatible)
1. Select VIs' folder to implement utility.
2. Do not forget to get back up of folder contents.
3. Run VI.
Note: This VI uses the subVI that does not reside in palettes. This subVI can reside in "Utility" folder in "Program Files." Also, make sure to make a backup copy of the folder of VIs before running this utility.
Comments
Eric_BOB
Member
Member
on
Thanks for this exempl, but just one question : Why do that ? Why turn off auto grow ?
Darren
Proven Zealot
Proven Zealot
on
As I mentioned in this blog post, I don't like Auto Grow because it often explodes my diagrams.  With auto grow disabled, I can manually resize structures when I want to.
-D
X.
Trusted Enthusiast
Trusted Enthusiast
on
Brilliant! I noticed some uncontrollable diagram explosion in a LV2010 VI opened in LV 2015 when browsing through nested structures and this tools fixed the problem in an instant.
jcarmody
Trusted Enthusiast
Trusted Enthusiast
on
Moo.
I've never had a diagram grow just by switching through a Case structure, but it happened today. Darren's utility saved my sanity postponed my breakdown.
Jim
