Example Code
Toggle User LED on cRIO Target
产品和环境
本部分要求填写创建该范例所需的产品和操作系统。
如要下载NI软件(包括以下所示产品),请访问ni.com/downloads
    硬件
  • CompactRIO|SingleBoardRIO
    软件
  • LabVIEW Real-Time Module
  • LabVIEW
代码和文档
添加附件
Overview
The example demonstrates how to toggle the Real-Time user LED at a user-defined interval.
Description
With the 'NI_Real-Time Target Support.lvlib:RT LEDs.vi' function the user can access one or multiple (depending on the hardware) LEDs. The LED can have either a single color (default: green) or an additional color (default: yellow). With the LED(s) and LED color(s) the Real-Time target can indicate a certain device state without the need for a Graphical User Interface (GUI).
In this example a single-color LED is toggled at a user-defined interval.
The following link shows an example blinking the FPGA LED with a FPGA VI:
https://forums.ni.com/t5/Example-Programs/Blink-LED-on-a-cRIO-Target/ta-p/3526764
Requirements
 Software
  • LabVIEW 2012 Base Development System (or compatible)
  • LabVIEW 2012 Real-Time Module (or compatible)
  • NI-CompactRIO 13.0 (or compatible)
 Hardware
  • any NI Real-Time Target with a user programmable LED (e.g. NI CompactRIO)
  1. (Optional) Change the toggle period
  2. Run the RT.vi
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text 'NIVerified'. Read here for more information about the new Example Guidelines and Community Platform.**
Anuar R.
National Instruments México y Latinoamérica
Ingeniería de Aplicaciones
www.ni.com/soporte
NI社区“代码范例交流区”(Example Code Exchange)中的代码范例已获得MIT许可
评论
JKSH
修改时间
You can toggle the LED by wiring '3' into the "State" terminal. You don't need to write your own code to toggle between '1' and '2'.
Certified LabVIEW Developer
