Example Code
Tick Count Elapsed Time to Timestamp Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI can be used to calculate the time between two tick counts and it will return the data in a timestamp data type.
Description
The tick counts are subtracted and then the days, hours, minutes, seconds, and fractional seconds are calculated. The result is turned into a timestamp data type. The time is checked to see if the time has exceeded the update interval and the Elapsed Time output is updated.
Requirements
Software:
  • LabVIEW 2012 (or compatible)
1. Run the VI.
2. Observe elapsed time as days, hours, minutes, seconds and milliseconds.
Steve B
Comments
PhillipBrooks
Active Participant
Active Participant
on
There is a nice function in the vi.lib/Utility folder that will return a high resolution time. This was added in LV 2010.
http://forums.ni.com/t5/LabVIEW/New-LV2010-VI-High-Resolution-Relative-Seconds/td-p/1213011
