New LV2010 VI: High Resolution Relative Seconds
There is a new VI in LV2010 which returns a high-resolution tick count, however it is not on the palettes, and there appears to be no documentation for it.  It is called <vilib>:Utility/High Resolution Relative Seconds.vi
21179i8B1F40AA2731F4DF
This is present on Windows 32-bit (at least).
Message 1 of 15
(14,285 Views)
Wow, that's a neat VI.  I didn't know about it either.  I checked its diagram...just a callback into an internal LabVIEW function...no cool hidden functions or anything...
Message 2 of 15
(14,279 Views)
Interesting.. :).
(Of course we could have made our own, along the lines of this tool ;).)
Message 3 of 15
(14,271 Views)
My version of that vi is password protected. If it nothing fancy why password protect it?
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 4 of 15
(14,226 Views)
It is also present in the Mac version.
Coq Rouge,
 I think one of the NI people said that VIs in vi.lib which are not on the palettes are subject to change and are not recommended for routine use.  These are often password protected, even though they do not contain any great secrets.
Lynn
Message 5 of 15
(14,211 Views)
Coq Rouge,
That sound at least reasonable. By the way is this VI used in some example, or somewhere else? Just curious 😉
Message 6 of 15
(14,199 Views)
I think we need a better explaination of what the VI output means.
21263iFD1A9FE509AB6F9B
Playing around I created this snippet-  Interesting results? Especially the Total elapsed time / mean = 0.5
"Should be" isn't "Is" -Jay
Message 7 of 15
(14,188 Views)
Jeff - not quite sure what you're doing here.  The loop is subtracting the current tick count from the previous difference -- so the first value in your array is negative near zero, and the rest are getting more and more negative.  The rest is pretty much meaningless - and if you show more digits on the division, you see it's almost 0.5 but not quite, and with a little thought, it will be obvious why that's the case.
The output of this function appears to be simply a high-res tick count (with a precision in the sub-microsecond range) that rolls over at some value - no idea what the "zero" is, but it seems arbitrary.  So using it will probably require a check of it being reset.  Perhaps someone with access to the block diagram can make a more definitive statement.
I don't think it's used in an example - I just noticed it in the directory.
Message 8 of 15
(14,147 Views)
DOH
Message 9 of 15
(14,098 Views)
Just wiring before coffee.  Not a good plan for me.
Fixing the code yields a open loop resolution of @1.2uSec with a Std dev variying with other processes being run.  Hmmm.  almost could use it to calculate the rest of the CPU load.....
Message 10 of 15
(14,088 Views)
