Example Code
Test Internet Connection in LabVIEW
Code and Documents
Overview
This example VI demonstrates the use of System Exec to test the network connection of current PC.
Description
This VI uses System Exec.vi from Connectivity Library to ping the website yahoo.com. The returned value shows the internet connection availability on current PC. This VI shows an example of using System Exec.vi and further usage could be explored.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Download the attached folder to your computer
  2. Open the VI " Test Internet 2012 NIVerified.vi".
  3. Run the VI.
VI Snippet
Regards
Prabhakant Patil
Comments
Silver_Shaper
on
HI really its very good.
Silver_Shaper | CLD
Prabhakant_Patil
on
Please click on like if you like it.
Your valuable suggestions are always welcome for the improvement.
Prabhakant
Regards
Prabhakant Patil
dany1
on
Nice, but how often can you ping a website before you get blacklisted? Let's say I need to check for internet connection every 30 seconds.
Also, delay is noticeable. Can we set to ping only once instead of the standard 4 times?
tusharjambhekar
on
change the command to ping yahoo.com -n 1.
now it will ping only once
GNDT
on
Very good idea!
LZD_Sydney
on
Hi, once again, how can I change the number of Pings to only 1? I can't seem to find where n is set to 4, to change it to 1.
I also have another question, how can I integrate this in a code, to re-establish internet connection, in case there is no connection? I need my program to check for connection, when for example disconnecting from the cable and connecting to wifi, and connect to the available options.
Seli6272@D
