Example Code
TDMS to ASCII File Converter Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example allows user to convert from the TDMS (a binary format) to ASCII files, which can be opened in any text editor
Description
This convertor allows user to select a delimiter, and generate a single file for all data or create an individual file with each group
The ASCII converter allows user to write files in the TDMS format to gain the performance advantages, then convert the file once it is written to a more easily accessible format.  This is also useful when using the built-in logging functionality of the DAQmx drive.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Insert a correct TDMS file path
  2. Field the correct destination file path and choose the group handling method.
  3. Run VI then will generate a new ASCII file path
Labview front panel
Al B.
Staff Software Engineer - TestStand
CTA/CLD
Comments
likewise
on
I have used the converter tool for converting my data acquired through a multi-function DAQmx card (PXIe-6396). While the vi technically operates very well, I am concerned about the correct data scaling. When I compare the converted data using the v12 VI on LV 2016 with the proprietary TDMS File Viewer (see https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/vi-lib/utility/tdms-file-viewer/tdms-file-...), the data differ:
Here is the TDMS Viewer output of the first 5 lines
0,524075 0,351363 0,702558
0,520087 0,349645 0,705598
0,522465 0,353551 0,711365
0,523434 0,352879 0,710115
0,524364 0,353793 0,708333
and here the result from TDMS to ASCII Convertor 2012 NIverified.vi
0,5189726336 0,3512462884 0,6960789317
0,5211136101 0,3491289421 0,6997128930
0,5229029664 0,3502384003 0,6999864170
0,5251455223 0,3511603444 0,7049958137
0,5220981468 0,3507540640 0,7089032998
It seems that different scaling operations have been applied. How do I know which data are correct ? They were read from the same .tdms file.
