Example Code
Synchronous Image for WebVI
Products and Environment
    Software
  • G Web Development Software
Code and Documents
Description
Synchronous Image gives a control similar to the URL Image control built-in to G Web Development Software but is intended to be used as an image that updates rapidly. See a demo in your browser.
Behavior of the G Web built-in URL Image:
  • Great for relatively static images or images that change infrequently
  • Behaves like the browser native <img> tag
  • Updating the url clears the image immediately and allows the image to progressively load if supported by the image
  • If updated too quickly can appear to flicker or appear to ignore the change in url (the url changes again before the image has loaded)
Behavior of the Synchronous Image example:
  • Great for images that change quickly
  • Updating the url is blocking and the image is only updated after loading has finished
  • Can only update the url as fast as the new image loads so no flickering in the image
Changelog
Release 2: Added Update Source By Byte Array
Release 1: First Release
Milan
Comments
Desruelle_luc
Trusted Enthusiast Trusted Enthusiast
Trusted Enthusiast
on
super ! bravo!
Luc Desruelle | Mon profil | Mon blog LabVIEW | Auteur livre LabVIEW : Programmation et applications - G Web
Certified LabVIEW Architect (CLA) & Certified TestStand Developper (CTD) | LabVIEW Champion
MESULOG - LinkedIn site | NERYS - NERYS Group
| directeur CEO MESULOG
| CODIR - NERYS group
Contributors
