Overview
When synchronizing SMC-based devices, T-Clk can be used. However in situations where you need to synchronize an SMC device with a non-SMC device, T-Clk will not work. In this example, I will describe the steps to synchronize a Multifunction DAQ device with an NI-SCOPE device. This can either be done in a continuous acquisition setting or a retriggerable acquisition setting. This is the continuous example
Description
If you are familiar with the examples that ship with the NI-SCOPE driver, you may notice that this looks similar to the "Fetch Forever" example. This is to get the continuous functionality out of our Scope device. The main components needed for continuous acquisition are a Software Reference Trigger and the "Fetch Relative To" niScope Property that we set to Read Pointer.
On the DAQ side, we use a basic continuous acquisition setup. The DAQ will act as the "Master" for this example which supplies the trigger to the Scope device.
For the synchronization, we need two main components.
1. Share a reference clock between the devices
2. Share a start trigger between the devices
In the Scope task, we use the niScope Configure Clock VI to instruct the Scope to use the PXI backplane clock. We also use the niScope Property "Start Trigger Source" to configure the Acquisition Arm Start Trigger. Lastly, the Scope task is started first to make sure we don't miss the trigger from the DAQ task.
In the DAQ task, we use the DAQmx Timing property "RefClk.Src" and "RefClk.Rate" to instruct the DAQ card to use the PXI backplane clock as well. Depending on the chassis, there may be two backplane clock options. Depending on your DAQ device and your chassis you may need to change the reference clock that is used. In either case, if there are two options, both backplane clocks are PLL'd, meaning that even if the devices use different backplane clocks, the acquisitions will still be phase coherent.
Requirements
Software
Hardware
very useful~~
Thank you!
This code was used to synchronize PXI-4462 and PXI-5922 using PXI_CLK10.
FYI, I was able to show the data after replacing the graph indicator.
