Example Code
Switch Application to Secondary Monitor / Screen
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
To switch monitor programmatically
Description:
This example application checks first whether multiple monitors are detected by your Operating System. It's good to check this so the use doesn't switch to a monitor that doesn't exist and then lose ability to see the application running! If there are multiple monitors, the switching button will be visible to the user, and they can click on it to switch an application from their primary monitor to the secondary monitor.
Instructions:
To implement this example:
  1. Run VI
  2. Click Primary Monitor button to switch monitor.
To execute this example:
  1. Install the required software.
  2. Open the VI and refer the Implement Steps
Requirements
Software
LabVIEW 2012 or compatible
Hardware
Imtiaz Chowdhury
Project Manager
Green Running / Austin Consultants
Comments
G-Money
NI Employee (retired)
on
Thanks for posting this!
