Example Code
String to Timestamp Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example shows how you can convert a string back to a timestamp
Description
It's easy to convert a timestamp to a string in LabVIEW, however, there isn't a native function the other way around! Here's a very simple example that shows how you can convert a string back to a timestamp
Requirements
  • LabVIEW 2012(or compatible)
    1. Run the vi.
Front Panel
VI Snippet
Imtiaz Chowdhury
Project Manager
Green Running / Austin Consultants
Comments
ara201
on
I've tried and it worked. But how do I syncronize with the time in the computer?
