Example Code
String Title Capitalisation Fixer
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This program will allow you to capitalise any title string so that it capitalises the first letter of each word while ignoring prepositions as one should when creating titles.
Description
The code works by scanning the string for spaces to determine the index at which the string is the first letter of a word and then re writes it to contain a capital. The code then ignores the prepositions by using an array of predefined prepositions which it scans the string for and rewrites them to contain no capital.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Write a string containing any combination of capitalised or non-capitalised letters and wire it to the Input String terminal.
  2. Place an indicator on the Result String terminal and see the magic happen.
VI Block Diagram
Larry Colvin
Associate Principal Engineer
Dyson Technology Ltd.
Comments
Richard_Ha
on
w
BruceMoyer
on
Where's the VI?
Larry.C
on
Sorry, I had forgotten to attach it. It is now up.
Larry Colvin
BruceMoyer
on
Thanks, I posted an edited version that also deals with articles and conjunctions that the previous VI was missing.  Also if the word is All Capitals then it deals with that differently (added an ALL Caps input terminal).
vishots.com
on
I'm not sure why you have 2 arrays for prepositions. Couldn't you just take the first array item and just convert it to lowercase on the fly?
