Example Code
String Limit using XControl Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This XControl is useful for limiting the number of characters a user can type into a string control.
Description
This XControl uses code written in two sub-vis to limit the number of characters that can be entered into the control.  The number of characters can be changed at run-time through the "String Length" property.  This XControl also comes with three other properties: BG Color, Text Color, and Font. Included is an example of how the XControl may be used.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Choose a string length.
  2. Run the VI and user only can type the certain length of number of characters.
VI Block Diagram
Regards
Prabhakant Patil
Comments
Prabhakant_Patil
on
Regards
Prabhakant Patil
Prabhakant_Patil
on
Any suggestions ????
Regards
Prabhakant Patil
GKE
on
useful xcontrol !
Would be nice to remove forbidden characters in string (e.g \t\s\r\n)
These characters could be defined in "forbid chr's" array like "string length".
syrpimp
on
very precise
Thank you & Best regards
syrpimp
“You must continue to gain expertise, but avoid thinking like an expert." -Denis Waitley
