Example Code
Stop Watch Digital
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview: This program implements a stopwatch with a digital display.
Description:
This code uses numeric functions, loop timing, and string manipulation functions to update two front panel indicators with the current system time and the time that has passed since the Run button was pressed.  The Wait (ms) function causes the While Loop to iterate once every 10 ms.  The program uses the iterations terminal to increment the timestamp value on the Stop Watch indicator.
Requirements: LabVIEW 2012 (or compatible), Hardware: none.
Steps to Implement or Execute Code:
1. Run the VI.
2. Stop the watch.
Additional Information or References:
Karthikeyan @ sivathasan
Karaikudi - 630006
India
hp: +919442047691
Comments
skrcsir
on
About Stop Watch Digital
Previously I made stop watch with analog disply, now I am made Digital clock by using real time value.
please send suggestion to me.
My Email is skrcsir@gmail.com
Karaikudi - 630006
India
hp: +919442047691
Thoric
Trusted Enthusiast Trusted Enthusiast
Trusted Enthusiast
on
Don't use a wait function to count accurate time, use a timed while loop to ensure good timekeeping.
Thoric (CLA, CLED, CTD and LabVIEW Champion)
