Example Code
Sort String Array Using Common Alphabetical and Numeric Logic
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example demonstrates how to sort an Array of strings that contains both numbers and letters.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Modify input array or use "Logical String Array Sort LV_2012_NI_Verified" as subVi
  2. Run the program
VI Block Diagram
Sincerely,
Jason Daming
Applications Engineer
http://www.ni.com/support
Comments
KrisnaWisnu
on
just what i am looking for.
Certified LabVIEW Developer (CLD)
Certified TestStand Developer (CTD)
Using LabVIEW 8.5.1 (2008) to LabVIEW 2024
Aventador
on
Thanks a ton mate ! Helped me big time in a crucial situation !
Subramanian
LabVIEW Developer
Life may control my car, but I steer it ! !
Penoff
on
Good but far from perfect. There are cases when the result just doesn't make sense. Also it doesn't care for negative numbers. All short strings come after the long ones. I am looking for quite some time for a good logical sorting algorythm, but I still can't find one that fulfills my needs.
JHaas
on
Beautiful....did just what I needed. Saved lots of time. Thanks!
Jim Haas
ashesman1
on
Awesome, thanks.  That got the job done from start of searching to implmented in two minutes!
nrosenberg340
on
Thanks for putting this together, works most of the time.  However, I find that it sorts everything with a 9x in it incorrectly.
I have a folder with 10k files, this sorts the files between 90-99 and shuffles in 901, 902, 903, etc.  Ie, the list I get out the other side is 90, 91, 901, 92, 902, etc.  Any ideas here?
Nate
