Example Code
Sleep, Shutdown, Restart and Lock Windows programmatically
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example uses the System Exec VI or Call Library Function Node to either sleep, shutdown, restart or lock a windows PC.
Description
This simple event driven VI uses the System Exec VI or Call Library Function Node to either sleep, shutdown, restart or lock a windows PC.
Call the "LockWorkstation" method within the "user32.dll" using a "Call Library Function Node"
Call the "SetSuspendState" method within the "powrprof.dll" using a "Call Library Function Node". Needs parameters 0,1,0.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Start the VI
  2. Click one of the buttons and the relevant task should execute.
Front Panel
VI Snippets
Tested on windows 7.  Written in LabVIEW 2011 with silver buttons then saved for previous in LabVIEW 8.6
Comments
programmindragon
on
The version that claims to be 8.6 is actually 2011 (11.0).  Could you please revert it.  Thank you.
Ron Deavers, CLD
lewboi
on
sorry dragon,  v8.6 is there now.  Thank you for letting me know.
kv8vsa
on
Hi Lewis. How about 8.0 too
lewboi
on
Done
Fred_A
on
Must we have administrator privileges on the computer to do that ?
yura_beno
on
Would this work on windows 8?
Also, I'm trying to get a LV exe to run during Connected Standby. Is it possible at all?
