Example Code
Simon Says game using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI implement the game Simon Says. Look and repeat the sequence.
Description
Simon says is developed using queued state machine design pattern. To play, follow the pattern by sound and light as far as you can remember it. The score indicates the level of difficulty.
Requirements
  • LabVIEW 2012 (or compatible)
1. Run VI
2. Press Play
3. Look the sequence.
4. Repeate the sequence in the right order
Top VI Block Diagram
Comments
BetaCommunityCo
on
cant access block diagram
would like to check out your block diagram.
BetaCommunityCo
on
cannot access block diagram
How can you classify this as code sharing if you have the block diagrams locked. If you do not open up your block diagram how do expect us to learn anything from your entry. Except for "HEY HE CAN CODE UP SIMON SAYS"
BetaCommunityCo
on
here is the password...
use simon123 to access the block diagram.
let me know how it works.
-Rachana
BetaCommunityCo
on
thanks
thanks for the password
