Overview
This VI implement the game Simon Says. Look and repeat the sequence.
Description
Simon says is developed using queued state machine design pattern. To play, follow the pattern by sound and light as far as you can remember it. The score indicates the level of difficulty.
Requirements
1. Run VI
2. Press Play
3. Look the sequence.
4. Repeate the sequence in the right order
Top VI Block Diagram
cant access block diagram
would like to check out your block diagram.
cannot access block diagram
How can you classify this as code sharing if you have the block diagrams locked. If you do not open up your block diagram how do expect us to learn anything from your entry. Except for "HEY HE CAN CODE UP SIMON SAYS"
here is the password...
use simon123 to access the block diagram.
let me know how it works.
-Rachana
thanks
thanks for the password
