Example Code
Silicon Labs USB MCU Library
Products and Environment
    Software
  • LabVIEW
    Driver
  • Other
Code and Documents
Overview
    This is a LabVIEW 2012 library for the USBExpress driver for Silicon Labs USB MCU's.
Description
    It wraps all the functions contained in the USBXpress dll in order to create LabVIEW VI equivalents. The Context Help and VI terminals are populated from the SiLabs Programmer's Guide, so the library is fairly well documented.
Requirements
    Software
    LabVIEW 2012(or compatible)
Hardware
    NI-DMM Device
    To install, unzip into the LabVIEW 2012\user.lib\ directory. The VI's will appear under User Libraries in the Functions palette.
** 12-08-2019, Rolf Kalbermatter, A new VI library has been attached "Silicon Labs USB MCU's LV2012 Corrected.zip" that changes the Read and Write functions to work. The previous were purely Import Library Wizard generated wrappers not handling the buffer parameters in a way that could even work. I don't have any hardware to test it but the previous functions could never have worked at all. I also took the liberty to clean up the other functions and correct the error status handling to something useful. **
Ben
Certified LabVIEW Associate Developer
Certified TestStand Developer
Comments
Tektronix TDS754C
on
Very Cool.  I was having concerns about needing to learn C in order to run C Code in LabView.  SI Labs
has all of its example coding for serial communication in C Code Examples.
Thanks so much
Valentin87
on
 Please explain how to connect for example to CP2103?
mujat
on
Does anybody know the meaning of the SI_STATUS output of these vi's? I see numbers like 0, 1, 6, 255.
Thank you.
ddavidd
on
Hi Ben,
is you VI lib works for all silicon labs USB MCU? I am working with C8051F380, when I use "SI Get Num Devices.vi", the return status is 255. what does that mean?  can you advice how to get start to use your lib to communicate with USB devices.
Rgds!
David
mehrarajat13
on
Hello
I am using c8051F381 controller and SI Get Num Devices.vi is working properly, SI Open.vi also working fine but when I try to write I receive code 6 as the SI_Status which according to the Datasheet is SI_INVALID_PARAMETER.
Please anybody help me how make this SI Write.vi and SI Read.vi work properly.
rolfk
Knight of NI Knight of NI
Knight of NI
on
Use the "Silicon Labs USB MCU's LV2012 Corrected.zip" archive instead. The VIs in the other two archives are basically the direct output from the Import Library Wizard and this Wizard can despite its name no magic. Getting automatically a fully working library from the limited information present in a header file would be a real magical feat. Every Import Library Wizard generated VI library needs to be carefully reviewed and reworked to do the right thing(TM).
Rolf Kalbermatter  My Blog
siiilverrr
on
Hello everyone! First of all, please forgive me for my bad english, but I need help. I have installed new version of library of VIs, but I cant understand how can I send message "0x33" by "SI Send.vi", if input is numeric array(called Buffer)? If it could be a string or numeric I'd understand, but it's not. I have tried to do this, but it's not working.
-Thank you all for your attention!
