Example Code
Servo Easing algorithm using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Description
Overview
This is an extension to my colour tracking project - myTracker. I used this Servo Easing algorithm on two servos in a pan/tilt mechanism in order too smoothen their movement, as they appeared to be "jerky" and made the colour tracking with the mechanism much harder than it had to be. The source of the algorithm can be found here.
Servo Easing is whenservos change their position gradually, first changing quickly and slowing down near the target position in order to make the movement smooth.
Description
The position values here range from 0.01 to 0.99 as you would provide the PWM terminals on a myRIO. The user has the ability to set the initial position target as well as change  the target in order to observe how the position changes over time. The example code initially has a 100ms delay in order to make it easier to see the dynamic behaviour of the algorithm, the delay can be set to 0 ms in order to see how the position would change in near real-time conditions. It is worth noting that the time in the code cannot have a a resolution finner than 1ms due to OS limitations, for example, being run on Windows.
Below you have the easing algorithm and an example that helps to visualise what the algorithm does.
Requirements
Software:
LabVIEW 2014(or compatible)
  1. Download the .zip file
  2. Set your desired configuration (a, x1, x2, degrees, etc)
  3. Run the VI
VI Block Diagram
Applications Engineer
National Instruments UK & Ireland
Comments
qasim03354420475
on
 hi, sir i run your program mytracker on myrio but it not work smoothly i don't understand how implement the ease algorithm on that project to smooth the motors.
qasim03354420475
on
[video]
