Example Code
Serial Port Forwarding (Port Sniffer/Logger)
Products and Environment
    Hardware
  • Instrument Control
    Software
  • LabVIEW
    Driver
  • NI VISA
Code and Documents
Overview
This example demonstrates reading data from one serial port and forwarding this data to be written out of another port. This is useful when there are multiple serial ports and you are interested in sniffing or monitoring the serial communication between two points.
Description
Read the data in from one port with VISA Read and write it to another port with VISA Write. Both ports need to be configured. This example also displays a log of the data read in so that it can be viewed on the front panel.
Requirements
Software
LabVIEW 8.6 (or compatible)
NI-VISA
  1. Configure the two serial ports (baud rate, data bits, parity, stop bits, and flow control)
  2. Use a property node to extract the number of bytes available at the serial port being read.
  3. Use VISA Read to read in the data. Use the value returned by the property node for the byte count input of VISA Read.
  4. Use VISA Write to write the data to the second port.
  5. Display the read data by formatting the string for the log.
  6. Close VISA sessions to both ports to free them up for other applications.
VI Snippet
Peter Flores
Applications Engineer
Comments
mrx 23
on
Could anyone upload the Block diagram of this project? Or a Labview v7.1 compatible vi file?
Thanks.
pflores
NI Employee (retired)
on
They're up!
Peter Flores
mrx 23
on
Thank you very much!
刘林
on
A good idea。
Huck
on
could someone point me to the Full block diagram of this so that i can attempt to rebuild it for myself in LabView 6.0 ?
aniketjha
on
Sorry, for bumping the old thread but my requirement is similar to this.
Is it possible that from 1 port i receive the data and forward this data to 2 port as well as receive the data from 2 ports and forward to the same single port?
ThamS
on
Contributors
