Example Code
Select Multiple Files With Native LabVIEW Dialog Box
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example shows how to display a customized file selection dialog box allowing the user to select mutiple files.
Description
It seems to be the general agreement that the only way to select multiple files in a file selection dialog box is through external calls, such as .NET, ActiveX, C# dll, etc. However, this can be easily implemented in LabVIEW. The example calls a subVI which is called File Dialog and is not available in the function palette.
It is the low level VI that is called by File Dialog Express VI, so you can just place that express VI in your block diagram, right-click the express VI icon and select "Open front panel", and then use its block diagram.
You can also browse to C:\Program Files\National Instruments\LabVIEW xx\vi.lib\express\express input\FileDialogBlock.llb to find it named subFile Dialog.vi or you can just use this example.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Run the VI
  2. Select multiple files browsing to any folder, by clicking Ctrl key
  3. Click Thanks LabVIEW!! button to close the dialog box and stop the VI
  4. Notice that if you click Cancel button in the file selection dialog box, error code 43 is returned. You can add code to delete that error, or you can connect the error wire to a case structure to determine what needs to be done in case the user cancels.
VI Block Diagram
Chris Van Horn
Applications Engineer
Comments
Sean-user
on
That is an unusual VI. Nice find! I don't know if I would use such a VI on a product or anything beyond 'play' code.
DCanQAlias
on
In LabVIEW 2011, this vi is no longer supported by NI.
You can edit the File Dialog express VI, though, and uncheck the option "Limit Selection to single item". Same result.
Mike.V
on
This code worked for me in LabVIEW 2011.  Thanks
GleMunyan
on
This was EXACTLY what I needed for an offline analysis VI to plot multiple files.  Thank You.
LeMur Technology Services, LLC
busko
on
WOW!!! It is right what I need!! Thanks a lot. I use LV2012, and it still works.
No it is so easy to combine data from different measurements in one.
Really -- many many many thanks!
RainbowShadow
on
Just what I needed, LV2014
cpip
on
Beautiful. This works even with LV2015 sp1.
