Example Code
Select Display Graph
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI allows the user to specify which plots are displayed from the same Waveform Graph. The user can select from four possible plots to display.
Description
This VI outputs four sinewaves to a waveform Graph with phase offsets. A property node is linked to the waveform graph and two properties are changed. The first property ActPlot allows the user to programmatically select the active plot. The second property 'Plot.Visible?' allows the user to pass a boolean value to enable or disable the visibility of the selected plot.
Requirements
LabVIEW 2012 (or compatible)
1. In order to run this example first open the included VI.
2. Select 'Run'
3. Toggle the switches to change the visibility of the plots on the Waveform Graph.
Francisco Arellano
National Instruments Mexico
Field Systems Engineer - Energy Segment
www.ni.com/soporte
Comments
priyawa2000
on
Could you please save it as labview 2009/2010 or lower. I cant open the file. And I have 2010. It was saying it cant be opened since it was save in 2011.
